surging issue please help
Hi Folks
My daughter has a 2006 Polo 1.4s 16v auto it developed a problem I can't get to the bottom of
Once started it Idles fine but shortly after it begins surging the revs drop then go back up and it sometimes cuts out but if you blip the throttle to about 3k or more it settles nicely and idles ok for a brief time before being erratic again.
When driving locally it does it constantly and sometime will cut out at junctions, but if you blip the throttle it'll run ok for a time.
On the motorway once you rev passed 3k it goes and will happily pootle along with the revs below that once you've gone passed it one time.
If you give it some gas it'll accelerate roughly till about 3k then clears although on the odd occasion it'll be rough beyond  3k revs.
It does it less when running on higher octane fuel, but does it all the time when running on 95 octane
I changed the MAP sensor and it went away but came back
Throttle has been synced
No codes on VCDS
Any help  gratefully appreciated
  • Replies 9
19 hours ago, Onefut said:
Hi Folks
Hi
Did you clean the throttle?
cleaned about 5k ago so should be ok
Hi
In that case I would clean the Air flow sensor with a spray.
49 minutes ago, vwfan3 said:
Hi
What air flow sensor ?? the OP has replaced the MAP/IAT sensor previously
Had similar problem on another members car of the same age a couple of years ago and that ended up with burnt valves as the problem, so I would get a wet & dry compression test done
On 12/11/2017 at 14:25, Onefut said:
Hi Folks
Hi
How soon did it come back ?
Also, what engine code is it and what is the mileage.
Well I hope it ain't a bloody valve as this is a replacement engine an only had about 55k on it when it went in about 5k ago
Having said that I do have 2 spare heads so while it is a pain it ain't the end of the world
Thanks for your suggestions folks
Edited by Onefut
Hi
Check for any air leaks.
Also replace the tiny diameter (5-8mm) vacuum hoses.
  • 9 months later...
turns out it was a dodgy pre cat lambda sensor
Thanks for that.
I am coming round to 'planned maintenance' on cars as well.
The lambda sensors should be changed every 50000 miles.
