1.8T in 9N or 9N3
Did anyone ever put a 1.8T engine in a 9N3 or 9N?
Also, did anyone ever put a 9N/9N3 on air ride suspension?
Edited by PSWPolo
  • Views 2.4k
As far as the 1.8T goes, VW put one in the 9n3 GTI (and the Ibiza FR which is about the same thing, but far more available), so it should be possible. I think the 3 and 4 cylinder engines use different subframes, so you'd probably be best starting with a whole car as a donor if you're doing a swap into a 1.2.
True. I'd love to see a 1.8T in a stock Polo, like a sleeper-style one.
Couple from back in the day, you'll need the photobucket fix installed
