6n Gear knob
Hi, I want to change my gear knob, most of the ones im looking at are screw on but the current one uses a clip i think? Any way to make a screw on shifter work?
Many Thanks,
Jack
  • Views 1k
The standard one is held on with a crimp, if you want to use a screw on one you will need the correct sized die and cut a thread into the shaft
Thanks!
