Jump to content
Mullen29
Mk2 polo breadvan, full space frame, 1043cc modified engine!
Recommended Posts
Mullen29
Hi everyone,
This is the start to my project of which I hope to complete through this year/ start of next year! It is going to be raced with the hopes to be able to be one of the quickest cars out there, the video below is what I'm against from, 120 ish micras to high reving fiat  unos! its not gonna be the easiest to be able to get up there but I think I can accomplish it? it is going to be fully spaced framed with the only bits belonging to the car being the panels and engine, but even the engine is going to be modified: with the hopes of getting it to rev to 9500 rpm with out shitting a rod lol!
Sunday 7th of January:
I bought the car and got it home and it is now sat out side, and will be sat there for another 2 weeks till I start to strip the remaining items off the shell and get ready to chop the floor and make a start to the space frame! (IF all goes to plan)
Edited by Mullen29
  • Like 3
Share this post
Link to post
Share on other sites
MartinB
Welcome!
Exciting looking project. Do keep us posted with updates :)
  • Like 1
Share this post
Link to post
dvderlm
Did you see the. recent  rolling road thread? 1 litre using AEE (1.6) camshaft and big valved head from HZ donor on AAU bottom end.
Share this post
Link to post
kiran_182
Top project, everyone will be on board with advice on how to get the best results
You never know Clubpolo may do some sponsorship for race season
Edited by kiran_182
Share this post
Link to post
kwijibo_coupe
I know the engines in these are very well balanced, will happily rev to 8000+ rpm without throwing a rod. The trick will be getting it to make power up that high in the rev range.
I will be keeping an eye on this project. Looks interesting.
Share this post
Link to post
mbusby993
Keeping an eye on this one! Looks like a good’un. :db:
Share this post
Link to post
kiran_182
My newman 270 has power to 8k but just noticed they do a 296 race cam
Edited by kiran_182
Share this post
Link to post
Mullen29
Can u put the link in please
Share this post
Link to post
Mullen29
And yeah should be good, I’m just waiting for confirmation on the car to make sure I can 100% use it!
Kiran I don’t think they will sponsor it?
I done a fair bit of re search and the bottom end can be why ever u want as long as it’s under 1130 and made by vw? It’s gonna be one hell of a project but I think it won’t be far off the top runners! Especially after some development?
I have been wanting to start it but with out conformation I’m having to wait!
Share this post
Link to post
kiran_182
Keeping the stroke and upping the comp gt pistons to 10.1 will help find a few more horses,
GK pistons have a 75 bore and compression of 11.0:1
Assuming all things are equal they should fit on your conrods and retain your 1043
  • Like 1
Share this post
Link to post
dvderlm
I've got GK pistons(not for sale :tongue:), but the valve lift is limited or you have to cut pockets for high lift long duration cam which lowers the CR.
Compression height is not standard and they are shorter than 1043 pistons, giving maybe 7:1 with a 1043 crank (Guess)
http://www.clubgti.com/archive/index.php/t-234927.html (wrongly says GK is hydraulic...nope, 8 bolt and solid lifters)
GK 42.65
HK 42.87
PY 40.17
1W 39.08
So what about flat pistons and an old HH head? Combustion chamber in the head can be skimmed or  0.7mm metal head gasket
https://www.bar-tek-tuning.com/polo-g40-cylinderheadgasket
 and massive duration Schrick mechy cam like a 316.
Edited by dvderlm
Share this post
Link to post
Mullen29
Sounds like a plan, below is the rule book! That way u can have a look and see which bits would suit? It’s a class 4!
http://www.national-autograss.co.uk/class-four.php
Edited by Mullen29
Share this post
Link to post
kiran_182
Didn't know you had to get a licence from nasa
Quick read says you can use any factory engine fitted to that chassis as std when in production and de-stroking is allowed
So you could destroke a gt to get 1130and 10.1 comp
Share this post
Link to post
kiran_182
3f gt bare block £100 delivered, bit pricey
Look at this on eBay http://www.ebay.co.uk/itm/232531782786
3f had an imrpoved oir return over the aav which was one of the issuee with the original design
Edited by kiran_182
Share this post
Link to post
Mullen29
So the 1043 bottom end would basically slot straight it a got block? Also what’s the advantage of the gt block? Bigger pistons? Stroke?
Share this post
Link to post
dvderlm
Same 75mm bore by 72mm stroke.
The oil passageway front left is larger in GT block (- probably in  most of the later hydraulic head engines). You'll be running high load hot so oil temp matters, and for that oil flow matters.
And the passageway is away from cylinder #1 water jacket - so overbore is less of a worry.
But 77mm overbore still looks practical maximum.
GT block may have more ribbing for strength, but someone else will have to confirm that. It looks like other 75mm bore 1.272 / 1.043 blocks to me from the ebay photos..
The 1.043 pistons are taller than 1.272 pistons, because the same 122mm rod is used, with a smaller throw crank.
I think kiran_182's suggesting the 75mm GT pistons. With the 1.043 crank and custom conrods to get 10:1 or more static CR. Will be something like 1039cc if piston bowls are 1cc smaller than AAV?HZ 1 litre  pistons. Mate that to an HK mechanical head, fit larger 110.5mm long  valves and you can fit a moderate lift Schrick 292 cam that will do ~8300rpm.
Or mate it to a GT hydraulic head, convert to solid lifters, titanium retainers and a catcams 300+ cam might get ~8500rpm. Not looked at wider valves for this because cost of hydro to solid.
Or use custom flat top  pistons (Honda pm6 75mm high compression but not domed? maybe oversize, think  they have 29.5mm compression height)  with custom conrods and early mechanical head (heron head) and you can fit wider 104mm long valves and a Schrick camshaft with big lift and 320+ duration and hit >9000rpm.
The rev numbers are from playing with daipipes in wayback machine playing with valve lifts and cam overlaps. Might be more or less in practice.
Or custom crank ?
Edited by dvderlm
  • Like 1
Share this post
Link to post
dvderlm
Can't find the agressive ramp catcams rally cam that was over 300. Maybe I was dreaming, or they no longer do it.
Share this post
Link to post
kiran_182
Also worth lighening the crank and fly and balancing them at the same time so it spins up quicker
Newman do a 296 race cam for mech heads but unsure if itd need cutouts
Looks like club polo are gonna build a race car
I have a spare bare skimmed gt head
Edited by kiran_182
:p
  • Like 1
Share this post
Link to post
dvderlm
Neman? Newman, of course. That's the solid /mech lift conversion and 8000rpm with no other mods?
http://www.newman-cams.com/wp-content/uploads/2017/12/newman-cams_catalogue_2018.pdf
.page 58
VOLP/296/440 with 11.17mm lift. Depends on the followers, but that's more than usual 10.
Edited by dvderlm
Share this post
Link to post
Mullen29
In deed club polo is building a race car I’m just glad everyone is so helpful bought it not knowing wether it would be any good and it’s come to the point where it should be a pretty good contender! Thank you every one for you are advice links ect, I really do appreciate it!
thanks
aaron
Edited by Mullen29
Share this post
Link to post
dvderlm
I plugged some numbers into daipipes, assuming the newman cam with 77mm bore and 60.5mm stroke with 10:1 compression and larger valves.
Max torque of 87nm just below 7000rpm and 68kw =92hp at 12,000rpm!
Are there any long straights in autocross or do corners matter more?
You'll want a lsd (quaife), then comes the final drive/gear ratio calculations.
Share this post
Link to post
Mullen29
It’s a oval circuit it’s more of a sprint than any thing, every track is on mud and consists of 4 corners
Share this post
Link to post
dvderlm
With 75mm bore and 59mm stroke it still hits peak torque of ~81nm over 7000 if the inlet ports are wide enough (38-40mm) with that 296 cam.
There's very little final drive choice with 084/085 gearboxes.
Might have to adjust the tyre/wheel size to be in the 6000-8000 rpm range in mostly third and fourth gear. Guessing at 50-80mph from the video.
Share this post
Link to post
Mullen29
I should of added we only use 1st and second through out the whole race
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • Clareyfairy81
      By Clareyfairy81
      Open to sensible offers.
      No modifications, as it was when it rolled out the factory.
      3 owners since new, main dealer service history for majority of the 30 years. Just under 87K miles on the clock. Starts first time and runs well.
      Maintenance work undertaken in past year: new exhaust, new rear beam, tyres have done approx. 500 miles, new brakes, new cambelt, and undersealed for protection.
      Original fabric is in good condition for age, radio cassette works perfectly. Paintwork is in good condition, no evidence of rust
      Drives beautifully, great fun to nip around town in. Manual gearbox is smooth throughout all changes.
      It has won best unmodified at local VW shows.
      Comes with winter storm cover.
      New MOT. Only selling as emigrating and can't take with us.
    • tommyjac1
      By tommyjac1
      40mm lower
      New dampers
      Refurbished wheel trims
      Carb stripped and cleaned
      Rear arches welded both sides
      Both new rear wheel bearings
      Rocker cover, carb cover and fan cover painted
      New sparkplugs, fuel filter and fan belt
      2 new front tyres
      New exhausts
      runs and drives with no problems at all
      Please email if interested or want more information
    • Rob Johnson
      By Rob Johnson
      Anyone have any idea why my 1.1 is not firing. It seems like fuel is not being pulled through as it is pooling in inlet manifold just under the carb. There was suction when I put my hand over the carb.
      Anyone else had this problem and know the solution.
    • ivogiev
      By ivogiev
      Hello,
      New price - prices to sell.
      I will do copy/paste from this add : mobile.de add
      The car is great , but I have almost no time for it and other projects on my head. I need the space. The car has new timing belt,new battery, new clutch and new fluids.
      It participated in our local VW Fest 2018 and draws a lot of attention. When I drive it people notice it.
      The list of modification is very long, the car was built for the purpose of track day use, but is not stripped out and is 100% streetable.
      It is not 100% ready, it needs sway bar install and fixing of small things.
      I am not having enough time , actually I am having almost none for it so that is why it is for sale.
      I am confident to say that such Polo does not exist anywhere in the world, so here is its specs:
      - ABU engine block with documents
      - AFH head and pistons, CR ~11,5:1
      - G40 gearbox plus 2 more gearboxes in perfect condition that go with the car ( have shorter gear ratios)
      - 4 carburators from Honda CBR900RR, jetted main jets and sealed air jet.
      - Custom airbox and custom made and calculated length of intake manifold
      - Custom 4-2-1 stainless steel exhaust manifold and SS exhaust system - all calculated for particular engine
      - Custom made suspension with coil overs, A-shaped LCAs' adjustable in all angles
      - Custom made frame to which the A-shaped LCAs' connect
      - Engine and transmission rest on stock 3 pieces engine mounts, plus added 4-th infront
      - Mega Squirt 2 - controls ignition when using petrol and carburators, constrols LPG injectors and ignition when LPG is used
      - LPG system spraying after carbs, tank in place of spare tyre
      - Deep Recaro front seats from 20th anniversary Golf MK.3 with reworked stock mounts to fit the Polo ( narrower)
      - 5x100mm conversion with 15 inch Audi A3 light rims ( 5,5 kgs/ each)
      - 1 inch brake master cylinder with 4 wheel disk brakes - 256mm vented fronts with ~235mm solid from Polo 9N on the back
      - Factory GT body with black roof vinyl in great shape, OE paint
      - Car puts down 115 wheel horse power, the attached graph is without the airbox and without the Mega Squirt - I used to run it on vacuum distributor without any electronics(can be returned in that configuration)
      - Prepared stock AFH intake manifold with BMW 2.0 throttle body and 190cc injectors - if decided to return to single throttle body
    • The_Fayz
      By The_Fayz
      Hi, I have a mk2 polo project, I have cleaned and checked the spark plugs, cleaned some of the carb jets but when I try to lift the clutch and move it, it dies, does any one have any ideas what to check or do next? I want to put some fresh fuel in aswell , thanks in advance
