Mk2 polo breadvan, full space frame, 1043cc modified engine!
6 hours ago, dvderlm said:
Those wiseco forged oversize pistons are very expensive.
Worrabout Mazda 323 E3 series (1980-87) pistons 77mm as std?
https://www.ebay.co.uk/itm/PISTON-FOR-MAZDA-323-FAMILIA-E3-ENG-1-3-1980-1987/162070378273
Thanks for that, I’m gonna use the head with the combustion chamber in the head so that means I’m looking for flat top pistons! I’m after some that are 77mm, forged and also slipper pistons ( short skirt)! Then use these Conrods out of the g40 as they should be the same? which are steel an give me the ability to rev higher: https://www.maxrpm.de/Forging-conrod-H-shaft-for-Polo-G40-high-strength-to-9000-RPM-4-pieces?gclid=Cj0KCQjw1q3VBRCFARIsAPHJXrG1Saj6-EwjW66NQScN4Ntk5ZBnmpC7-UY8L9APx522ISaeg9E9XO8aAqJvEALw_wcB
  • Replies 52
  • Views 10k
  • Welcome!   Exciting looking project. Do keep us posted with updates :)
  • Keeping the stroke and upping the comp gt pistons to 10.1 will help find a few more horses,    GK pistons have a 75 bore and compression of 11.0:1    Assuming all things are equal
  • Same 75mm bore by 72mm stroke.   The oil passageway front left is larger in GT block (- probably in  most of the later hydraulic head engines). You'll be running high load hot so oil temp ma
Combustion chamber in head is liked by ze Germans.
If you use standard sized 122mm rods you need pistons with same compression height as HZ?
Motorbike pistons (cbr1000rr 2007- is 76mm bore I think) and custom rods?
Honda Gx270 piston? nearly flat, 77mm as standard. Looks quite tall 59mm?. Just need to find compression height and pin diameter.
(not short skirt slipper though).
