Engine conversion afh
 I plan on doing  a afh engine conversion in my mark 3 coupe  I am picking the engine up this weekend  Does anybody know if I need the engine bay wiring loom  cheers  as the guy has asked me if I want it
  • Views 559
If you intend running it on its standard injection setup ? then you will need the loom/ECU/ and get the immobiliser deleted from the ECU  If you intend running on bike carbs then you could cobble up the original loom to get it running with some bits from a MK2 like the dizzy/coil pack amp  but I would get the AFH loom then it gives you more options
I plan to put on bike carbs but I'll get the  AFH loom as well  thanks for your help mate
