Hi All,
Before I go ahead and buy one.... thought I'd ask the question first.
I have just fitted my GRP wings and noticed the Front Valance has had a small knock (Dented Corner) Looks like someone has tried to straighten but doesn't line up with wings.
I would like to replace the whole panel but what is it like fitting a Lower front Valance?
Could I use a bolt on technique or would it need to be spot welded?
any info greatly needed and with thanks.
  • Views 998
its welded on
Thanks STeve,
Is welded a must? or could it be fitted with bolts?
Many thanks
i think welding would be best mate...cant you repair the original one?
Well its quite misshaped steve, I maybe able to... I can pop a picture up, if you can give me an idea? will be tomorrow though as car is at home.
