6R Gti Dipped Beam
Picked up a polo gti last weekend and all has been well.
However nipped in to shop last and when i started car back up no dipped beam on either side, no light warning on dash, main beam and sidelights still work, and no fuses blown.
Anything else i should be checking or is this a common problem with the switch itself?
Part# 6R 0941531 J
Edited by RileyAbz
  • Views 802
I would take one bulb out and check it.
Check your fuses and make sure your relays are all pushed in tight. I'm thinking there might be more to it though, so it might be worth having the fault codes read.
