57 Polo rear bleed size.
After changing the rear shoes and handbrake cable I want to bleed the brakes.  I need to know what size the nut is asi don't have a spanner that small.
I tried to use an old box bike spanner but even that was too big.
Anyone know.  It's got to be 4 or 5mm. Can you buy a bleed spanner that small?
  • Views 934
I tend to go with a pair of molegrips on the small ones. Make sure you've given them a good soak in release spray first.
  • 7 months later...
Thanks, I'll try that .
