6N2 Foam Inner Door panel
Needed to replace the window motor and when I took the door card off, the inner foam panel has been wrecked.
Does anyone know if you can get these new ? or a good substitute?replacement ?
  • Views 1.3k
I think Gsf used to sell foam sheet intended for this, but a big strong plastic shopping bag from one of the DIY stores works just fine.
Thanks for the pointer there dvderlm. Much appreciated...  :good:
I used the thermal underlay for laminate wood flooring from B&Q
Thats a bloody good idea. I reckon I'll give that a whirl.
Cheers Nige
