gt conversion idles badly- no hot start
abd engine that previously ran fine on carb
fitted all 3f mpi bits except the cam
starts from cold and sounds normal , quickly starts to sound rough with a unhappy idle , with the blue sender undone it runs worse ive attempted to set up the timing but unsure if the rough idle effects it..above idle it sounds better and drives semi okay
when hot it will not restart - after one hour it starts again
tried 2x temp senders , new coil , ecu and (correct)dizzy works on my mates gt ,car has no o2 sensor at present,  fuel pumps are running when it refuses to hot start
ive about reached the end of my knowledge and unsure what to do now
  • Replies 9
  • Views 868
Cooper insert for the starter?  Hg going? Isv or tps
Rough idle and warm start are probably sepserate issues. Does advancing the dizzy smooth it out
Which cam is in?
Edited by kiran_182
cranks fine when hot just wont start
no reason to think its head gasket , its done 1500 on the carb sinse a reasonbly thourough rebuild , ive not touched the engine just took carb off and mpi on
runs smoothest where dizzy is now...5 deg , although with it running so ropey im not convinced its entering service mode as it should
stock 1300 mh cam at the moment
Lack of lambda sensor could be the rough running
If you wind the brass screw on the right of the tb out itll up the idle by altering the mix,
Best to wind it down / right first to find out how many turns out it was.
Edited by kiran_182
ive messed with the idle screw ...winding it in makes it slower , winding it out gets it roughly 900 ish but cant get it much higher , doesnt respond like it id expect it to
Jam a skrew driver under the throttle arm and start it up, see if incrrased revs make a difference
If it still bogs doewn with full throttle theres an air leak
does sound ok above idle
got a video for us?
Hi,
I had a hot start problem on my gt, I hunted for the problem for literally a year, changing pretty much everything without getting to the bottom of it. Found a work around, described below, until I replaced the battery for a different reason and it solved it. Unfortunately can’t explain why or the theory behind it but not had the problem since.
Work around:
So once warm and not starting if you unplug the blue temp sensor and try to start the car, mine fired up and then cut out almost immediately, I’d then replug the blue temp sensor and it’d start fine.
I ended up putting a break in the blue temp sensor wiring and fitting a switch on the dash, so I could basically just turn the switch off to disconnect the sensor then back on again to reconnect.
Hope any of that helps
