6n2 idle problems
Hi guys, new to the forums.
My polo seems to have some idle issues.
Month after I bought the car, I noticed that its idle sound wasnt normal and it has been getting gradually worse.
Week ago the engine misfired while I was waiting for my friend from the store.
I took it to the shop to get the fault codes.
I cant remember the exact codes but it statet that injectors 1, 2, 3, 4 and lambda2 sensor has some problems with grounding (shortcircuit ?).
I can provide more information if needed.
Thanks in advance.
Edit. The car is 2001 1.0 mpi auc
Edited by Doddger
  • Views 565
Popular Days
Welcome to the Forum.
I have only just spotted your post,.
Rather than referring to 'shorting' (short circuit) I would imagine that the problem is with poor earth connections (ground connections is something of an Americanism)
The injectors are earthed via the ECU, so I would suggest that you start by checking the ECU earth - It might also pay to check that the connections in the engine multi-plug are free from corrosion.
Regards.
