Hello all.
Recently my Polo's driver door lock latch "broke" inside the cylinder and is preventing me from inserting the key, hence unable to lock/unlock the car from the driver side. I can do so via the passenger side but can get annoying after a while. Is there any way this can be fixed or does the whole cylinder need to be replaced? Image below should show what I mean.
I appreciate the help in advance.
  • Views 824
Popular Days
It looks to me as if the little cover that should slide out of the way when the key is inserted, has somehow become detached and is blocking the key from entering.
It probably isn't repairable, but you could try picking up a second hand barrel AND KEY - The snag with that is, that you would almost certainly finish up with different keys for the two doors - BUT, once you have the new barrel, you could have a go at the old one and see if you can repair it.
You could try www.stevensvwspares.com for a barrel and key.
Regards
