painting over paint? engine bay respray
engine bay respray with rattle cans
do you have to take every bit of the paint off and get it down to bare metal?
because an orbital sander would be hard work to take the paint off.
i think of only using a wire wheel with a drill but seems drastic .
  • Replies 24
  • Views 2.3k
  • steveo3002
    steveo3002
    i guess not , its fast drying anyway so i doubt it will help you , its meant for bare metal   the way a painter checks the surface is to wipe it down with panel wipe and catch the surface in
  • steveo3002
    steveo3002
    https://www.ebay.co.uk/itm/U-POL-Fantastic-Lightweight-Body-Polyester-Filler-1-4-LTR-Inc-Hardener-BEST/323233966548?epid=678940163&hash=item4b423ee9d4:g:~eEAAOSw6LNa56KU   is decent
no , the factory paint will be way more protection so dont strip it off unless peeling /flaking
use a red scotch pad to scrub at the old paint to provide a key , you need to work at it until its all dull paying extra attention to corners and creases and anywhere that see's more wear ..the pads can be used with warm soapy water or panel wipe
yeah ive just bought some red scotch pads and an etch primer for the rust parts.
one question steve, there are parts where the paint has peeled because of rust. do i sand this part down, use a filler to get it level with the factory paint, then sand it like you said to key it in then spray etch primer on the whole thing.  before putting on the main coats.
yeah sand it until its clean metal , try and get any pits clean with a dremel /wire wheel , go through the grades of paper and make sure its finished with 180 or 240 , just etch the bare metal , no need to etch the sound original paint
and yes if its pitted badly then use filler ..but as i said preferably over 100% clean metal  or the rust will be back ...bilt hamber deox gel works well if you use enough
any harm in etch priming the whole thing grey including factory paint?  I just thought it would be a easier way to check for any defects when shining a light on it all.
making sure it's all smooth looking
the way a painter checks the surface is to wipe it down with panel wipe and catch the surface in the light at the right angle , shows up any defects
you could also go over it with this just before painting ..helps the paint bond
https://www.ebay.co.uk/itm/UPol-Grip-4-1K-Universal-Adhesion-Promoter-450ml-Aerosol-Can-clear-GRIP-AL/323234033081?epid=547503408&hash=item4b423fedb9:g:Nr0AAOSw4J5a57B9
you know that bilt hamber gel you use.
1)do you still need to sand any rust off if your going to use that gel? from youtube vids seem you just apply it and it takes away the rust to bare metal
2) also is a must to shrinkwrap any part you have applied it too?
yeah clean it up first otherwise it would take more gel
put a thick layer on and cover it , once its turned black its used up , rinse it off and do it again until theres no rust pits , will take several goes over a few days to clean it up well
I did mine, looked really good i just thourally cleaned and degreased it, scotch pads are great as said, get some good quality clear on top, cheap stuff fades after a while.
guys, do you have to spray on the underside of the chassis beams?
hard to get to those underneath parts and the parts that are near the subframe.
those parts dont get seen anyway when engine is in
dont have to paint anything you dont want to ...personally id try and do as much as possible
bilt hamber was pretty good. on the chasis leg it took three times though to get ride of the rust. I've got 99% off, Just a few dots (pits). Might just etch prime over those.
Ive also used it on the engine mount covers. My question is, shall I take the engine mount covers for powder coating or just use 2K paint finished with a 2K clear coat?
up to you both work fine...personal choice
although once damaged powder coat is harder to touch up /redo
because it's powder coating is thicker?
i've bought some steel body filler so after i take off the rust with the gell, again will etch prime to prevent rust return. roughen it back up with sand paper and use the filler to get it smooth.  finish off with painting
harder because its melted on powder ...vs a repair with a paint brush on painted jobs
fill onto bare metal or epoxy primer only....NOT OVER ETCH
aah bugger, etched it now.
i will sand it rough, i did read quite a few  posts from forums that you can do it either way aslong as you roughen the surface.
https://www.hotrodders.com/forum/can-you-put-filler-over-self-etching-primer-safely-121000.html
the etch primer protects rust from returning. it would defeat the object using the filler first because the filler is prone to moisture.
it seems it's one of those topics that is hotly debated for and against, i did think about it hard before choose to etch the the clean steel the rust was removed from.
etch takes on moisture too
the only primer that doesnt is epoxy
much like your link says
Edited by steveo3002
steve, as i have etch primed the  rust partrs as the etch has chemicals which will stop rust from returning or growing if there were any pits left. and u suggest no filler on top of that.
can i now put some expoxy primer over the  etch primer where i want to put the filler to give it a smooth finish. theres only 4  of  30mm patches that i want to fill
proper answer no
if you want to do it right thinners it off and epoxy it
So what is the etch primer used for then? obsiuly bought the wrong stuff
Bought two cans for nowt
ill sand it back off the where rust was no problem . that aint a big deal then epoxy primer like you said
but can i leave the odd parts where it was over the normal paint. it was a proper thing coat lol
Edited by damunk
etch is used to help further coats of primer adhere to the steel , it contains acid and etches/bites into the steel so that it sticks
its not the wrong stuff , just isnt used under filler - for etch you would fill any defects onto clean bare steel , then etch any bare metal spots then on with high build primer
or
epoxy primer is more modern and better performing - you can coat the whole project to seal it first then fill over it , or fill the dents then epoxy over the whole thing
both are acceptable ways to do a nice job...you just need to follow the correct steps , if youre able to use epoxy then do so its much better and doesnt soak up the moisture at all
I have now been told dont need the filler. the dimples and rough texture left by rust remover apparently will smoothen off after a couple of coats of high build primer or top coats.
might just fill it with the etch paint and sand it smooth. we talking 0.1 -  0.3mm
so bought a tin of filler for no reason
