Polo breadvan lighting relay
Hi all
I have a 1984 polo bredvan and my relay keeps clicking on and off so I am wondering if anyone know which relays are for what as I believe it is the lighting relay at fault
thanks
  • Views 892
they dont come with a headlight relay...unless someone had fitted a modified loom
When do you get this 'clicking' - it may or may not be a relay sound.
Does everything else work OK and does the car drive normally?
Regards
Everything works as it should but the clicking can sometimes be on all the time but sometimes can be fine but reason for me thinking it could be lighting relay is sometimes it goes off if you switch lights on but sometimes stays on thanks
I can’t think what else it could be other than a relay anyone know
look for the noise and feel any relays to see if its that clicking...could be something someone has added onto the car?
