Ambient Temperature Sensor - 6N2
Hi all,
I recently bought the chrome dial set from the GTI variant for my 1.4 (6N2 model). And this has got me wanting to try fit a ambient temperature sensor (which as they’re the same platform I imagine is possible), however never having looked over a gti to see where it would mount and the cabling goes I’ve hit a bit of a brick wall!
Is anyone able to shed some light on where the sensor sits and cables run?
  • Views 1.5k
  • First Welcome to the forum.   The sensor sits behind the bumper cover on the passenger side, you might be lucky and find the wiring is already there, if not it only requires one wire to be r
The sensor sits behind the bumper cover on the passenger side, you might be lucky and find the wiring is already there, if not it only requires one wire to be run through the fusebox to the speedo and a ground wire
Cheers! I’ll tackle it this weekend and see how it plays out!
