Positive camber issue
Hi,
i have lowered my VW Polo 6n and seem to be getting positive camber in the front only on one side though... so basically instead of the wheel sitting out it’s pointing inwards! Very strange I think the previous owner has used washers on the rear...
does anyone have a clue how I can resolve this? I don’t mind using washers if I have to! Just want to stop it driving odd and feel like I’m driving on my outer sidewall!
Any helo would be grand!
  • Views 1.5k
Popular Days
The camber can be adjusted to a small amount with the two bolts that hold the strut to the wheel hub assembly, slacken the two bolts #32 in this diagram https://volkswagen.7zap.com/en/rdw/polo+derby+vento-ind/po/1998-158/4/407-407010/#32  then push the top of the hub (#7) inwards and tighten the bolts back up, then take it for a wheel alignment where they can set it up to the correct camber
