gt /3f runs rich- wont run lean
Yes reading went higher with oil squirted in, just about equal gain for all cylinders, but not a massive amount - in the 0.6 to 0.8 bar range  - so under 10% rise. I see 14 to 15 bar on my re-ringed 11:1 compression engine when warm, dry test.
  • Replies 145
  • Views 11.2k
  • was about -.75 bar so around 22 inches
  • I found 10.5 on Wikipedia, lol https://en.wikipedia.org/wiki/List_of_discontinued_Volkswagen_Group_petrol_engines   Yes, it's not awful. I'd prefer to see over 140psi and #4 is more tha
  • right - getting somewhere now    new /refurb head is on , confirmed it is the gt cam too   exh sounds smooth now with an untouched afm ...havent tested the emissions yet but should
righto...if mines piston trouble i guess it would be a broken ring as maybe you recall i honed and re ringed it , but ran fine on the carb with great emiisions
With 22inHg steady reading at idle I'll be very surprised if anything mechanical is up.
You can test all rings at once with vac gauge too. Open throttle to 2000rpm and let it snap closed. Vacuum should head towards below 3inHg  but not quite reach 0 then hit nearly 25 inHg when close and settle back to 22 idle.  The deceleration phase is pulling air by engine spinning inertia against closed throttle. If a ring is bad it wont seal on the downwards stroke.
https://dannysengineportal.com/checking-your-engine-with-a-vacuum-guage/
Mityvac are ace. You can neasure and override the vacuum for something.
New theory. The Fuel Pressure Regulator is giving correct pressure at output port but leaking fuel down the vacuum control tube into the manifold?
It'd be rich, but uncontrolled rich and with no vacuum loss. High CO, high HC and you had what looked like clean oil that could not be from a breather?
I think the FPR is on end of fuel rail on MPI.
yeah not a bad idea ...maybe i should look at it more
i applied some vac to the fpr and it holds steady , fuel pressure reads as it should with and without vac , i do have another i can swap over
yeah the tool sounds pretty cool if you know how to use it
I doubt that the rings are causing your problem, but when you say that you honed the bores before fitting new rings, did you also scrape off the wear ridge near the top of the cylinders? What can happen (I am not saying that it has happened in your case) is that a new ring CAN strike the bottom of the wear ridge and brake the ring.
Regards
wasnt a noticable ridge ...just gave it a light hone so the rings would bed in
assume a broken ring would make a noise /smoke which theres  none
See what the compression tester reads?
just opened up a spare ecu (runs same)   and noticed these look like theyve been hot
think its a voltage reg , theres one each side of the board
should i be replacing them or what lol
If they are regulators, not IGBT transistor ignition drivers.
Oh, plenty of spares I see. That's one benefit of living in Silicon Fen.
Integrated circuits grow on trees around here: Acorn, Raspberry, Apricot, Apple, Bush, Thorn, Blackberry.
theyre not my spares
will look into it further  see if i can get some part numbers
Arw you getting excessive hydro carbons
cold compresion results
1*  150
2* 170
3*170
4*140 ?
i did *4 first and fear i might have not cranked it enough....ive dropped the adaptor down near the starter so will try it another day when i retrieve it
all plugs same colour and fairly normal looking  , while its not text book readings i think its probably near enough that it should run acceptably?
If you can see gauge while cranking keep going until it stops rising.
I chucked some figures in a cranking calculator and reached 174psi for 10.5:1 of ABD. (Not sure about rod length or ABDC inlet valve  closing)
http://not2fast.com/turbo/compression/cranking_pressure.shtml
image.png.28700cfed926af5d9ef51fc91db4d06b.png.
I can get the 220psi of my best cylinder with the same calculator and values I'm reasonably sure about.
acdc atdc abdc abcd
9.5-1 according to this
regardless...do you agree while not ideal its not so hideous to cause major issues ?
will try again with a warmed engine some time919376249_enginespec.jpg.0aa89e64242e2ace854d9b08d8333310.jpg
Yes, it's not awful. I'd prefer to see over 140psi and #4 is more than 10% below best cylinder, but for cold reading nothing there shouts bust.
You could try it from #1 to #4 next time cold.
okay your cam seat to seat duration is not as wild as 290. (fudging that, using 78.7mm stroke as inches, but rod length still a guess).
magnet on piece of string?
its brass lol...think i can poke at it with a coat hanger hopefully it will fall out the bottom
Disconnect the battery if you doing that with a metal coat hanger near starter motor terminal!.
I branded my thumb poking below my carbs with some wire.
vw specs 10-15 bar
max 3 bar differance ...so a pass , i will consider it good enough
10bar is 145psi and you got 140 psi = 9.65bar for cylinder#4.  But cold measurement with oil very viscous, so I agree, probably okay.
Still a mystery.
right still no progress , tried yet another ecu i borrowed just the same
ive swapped every component that makes the engine run , most of them more than once , tried timing all over the place
do you think id be mad to pull the head and have a better look ...try some liquid behind the valves see if they leak ?   ive got most of the stuff  already just need a h/g and bolts
or honestly what would you do
Get a bore scope and have alook first?
borescope wont tell me about the valves...think i will just pull it unless anyone has any other ideas
will cost me like £40 which ive been throwing at it weekly in parts and tools to try and fix it
