timing belt change 6n afh
timing belt change
on the afh it seems the drive pulley which sits on the crank pulley covers a little of the timing belt tensionor bolt which doesn't allow a torque wrench to go over the bolt.
it's a daft design if im right, it means you have to take off the drive pulley , undo the alternator tensioner, take off drive belt.
anyone here done a belt change on afh?
  • Views 992
