Engine idles down and cuts out
Abd 3f injection.
Start the car and runs fine for 3 or 4 min then idles low and cuts out, wont repond to throttle when chugging and ramind this way on restart unless left
Any ideas
  • Replies 47
  • Views 2.9k
id suggest you get the diag leads and vcds and have a look for fault codes , can also read a few live data feeds like temp /tps/lambda etc
Hall sender failure is a bit like that. Cuts out randomly, but will start again once cooled down.
But the slowing idle is an odd one. Is it smooth or lumpy idle?
If smooth - fuel delivery, otherwise electrical issue in my experience.
As suggested above, my last lambda resulted in similar symptoms of the idle degrading after a few minutes as it all starts to warm up. Can always test it, multimeter readings are deffinately on here somewhere. Same for the temp sensor, theres a range of resistance or voltage readings over a range of temperatures. Mine idled like crap as the ECU began using the faulty sensors signal.
More recently had a worsening fuel leak on one of the rubber pipes which in the beginning I'd get a few miles then it would start chugging then eventually cut out, throttle would do nothing to help obviously. The car was said to be getting a little filler neck rot on the last mot so fuel smell wasn't surprising untill it stank, by that point it wouldn't run at all though, been in the garage waiting for time to put the fuel tank in but fixed the leak and it runs pretty damn well now.
Goodluck
you can unplug the o2 to prove it...should run well without one
also it wont come into play until the engine is warm ...
Its chugs as it idles low so electrical is probably right. Ill try it with the lambda un plugged and see
assume youre aware of how to set up a gt ?    ajust the idle and timing etc?
Yeah ive already wound the idle out advanced the dizzy and to see what happens. Used all my little tricks and not happy with running it this way
Edited by kiran_182
so was this a running gt that youve just changed the engine over?
Abd head and block on gt injection
Put the obd on.amd got 5 codes
• Intake air temp sensor - no signal
• Engine coolent temp sensor - open / short
• potentiometer for air flow meter - no signal
• oxygen sensor - no signal
• throttle position sensor - no signal
I recal un plugging somemof these when testing so they may not be current
does your scanner do the live data
Got the multimeter out and tested reistance on the loom
Ecu connector ports, resistance ohms
1 2.0
2 0.8
3 0.8
4 blank
5 blank
6 0.8
7 blank
8 0.6
9 0.8
10 0.6
11 0.6
12 0.6
13 2.7
14 0.8
15 blank
16 blank
17 0.6
18 0.7
19 2.4
20 no signal - later found to be obd
21 0.7
22 blank
23 0.6
24 0.6
25 0.6
This is the pin data from Autodata Polo 3f Inj Pin Data.pdf
This is probably a shot in the dark but I had a very similar problem but would cut out at random and it turned out to be warn out HT leads
Got a timing light on it today. started off running ok but needed full advance could still hear it fighting to run after a min or two it idled down and chugged with the light going out for long periods at a time
might suggest the cam timing is out
Took some pics of the timing marks
Got a few hours on it today. altered the timing mark, with the cam timed the crank mark is just under the right tab
Got thw car to run fairly well for 20 odd min but once hot it splutterd and struggled to restart, would missfire when you turn ignition on, before you try crank
have you got the correct fuel pump relay...mine wouldnt hot start with the wrong one
Ive been overlooking that. Ill check it out.
This is from thur
Went to start today and it cranked but wouldnt fire
Not quite sewing machine sound is it. More like a hay thresher.
You were losing sparks, if you mean the timing light was not flashing in synch with cylinder 1 when it was 'chugging'.
The first vid i got was more sewing maching, this is idle screw wound out and full advance to run with trottle to start
Sure, but it should not need that much advance.
Did you check the fuel pump relay?
My bet is Hall sender. The rest of the ignition technology is solid-state and away from engine heat/oil.
What happened when you unplugged lambda?
