Advice on changing rear splash guard
Hello again.
I hope your not getting tired of me yet!
I noticed the splash plates behind the rear disks are rotten. Ive googled hard but no idea. How do i change these? Am i going to have to take the disk off or can i get from behind?
Car is 6n2 1.4 se
Cheers again 🙂
  • Views 801
  • You will need to remove the disc's from the hub units but that is simple as the disc is only held in place with a single screw (if it's still there ) you will need to also remove the caliper carrier (
  • The screw or bolt will be very rusty so soak in wd40 or penetraitng oil for a day or so before improve your chances
You will need to remove the disc's from the hub units but that is simple as the disc is only held in place with a single screw (if it's still there ) you will need to also remove the caliper carrier (#2 in the link below) from the axle before you can get the disc out.
Here's alink to the part number https://volkswagen.7zap.com/en/rdw/polo+derby+vento-ind/po/2001-240/6/615-615060/#8
Edited by kiran_182
Cheers will do. I probably wont get round to it till i get the sump plug sorted!
