Rear GT beam bush replacement help.
I got my GT beam out at the moment and would like info help on getting the old rubber bushes out and installing new ones.
Many thanks.
  • Views 1k
they push out easily , think i tapped mine a hammer or you could use a large clamp to push them out , pulled the new ones in with some soapy water and a G clamp...theyre not hard to do like most modern cars
Excellent I thought is would be a game to do. Thanks.
If you remove the clamps from the chasis dont clean it, the marks from where is was will help get it in the right place
Yes I done the same last time . Thanks for the reminder..I shall start new thread on gt breadvan soon..
