New heater resistor fishy burning smell
My polo 1.0 se’s Blower would only work on number 4, so I did some research and discovered that it was the heater resistor. I replaced it and now the blower works on all 4, however there is a fishy burning sort of smell when the blower is on either 1,2 or 3. I wondered if anyone knows what the cause of this is and what I should do?
  • Views 3.2k
  • Usually that smell is a glue somewhere in the dash vent system or could be on the resistor
  • caretakerplus
    caretakerplus
    Some plastics give off the smell as you describe when they are heated. If the resistor pack that you fitted was NOT genuine VW, I would suggest that you check that there are no signs of overheati
If the resistor pack that you fitted was NOT genuine VW, I would suggest that you check that there are no signs of overheating on it, as there is a possibility of a fire risk.
Hopefully it will be OK and it is just preservative that is burning off BUT it would be advisable to check.
Regards
