mk2 heater matrix replacement
Leaky heater in Mk2. Is this a dashboard out job or can it all be done from the scuttle tray
  • Views 1.8k
  • mr brightside
    mr brightside
    Thanks. So the section in the scuttle clips onto the bit that's in the car behind the dash with those springy U-clips?
Yes, from scuttle tray.
Clips on the fan housing slide to outer edges left and right.
I can't remember whether I  had to unclip the heater unit cold/hot cable at valve on heater.
Flush the system if you are fully draining it rather than clamping hoses..
Great- thanks mate. It's recently been flushed so I shall clamp ;)
  • 7 years later...
Looks like i'm doing this job this year, do you have to remove the whole fan/matrix unit completely or will the matrix slide out sideways? Do you have to split the fan box in half?
Might be different on a RHD car. I could not slide it out sideways because the wiper motor is in the way for me.
Hose clamps or a joining pipe. Slide 2 clips, heater resistor connection, I can't remember whether I released the cable attached to the inlet valve.
Exploded diagram
27 is the clip (one of them)
That's right, yes. You can normally slide them off the end of where they're hooked unto, rather than firing them across the garden with a screwdriver.
