fuel tank neck repair
No, had to give up and head back home before I even reached the A14. Engine was dying at roundabouts, but pulling well when pumping the gas pedal or over 3000rpm.
I had put 20 more litres of fuel in so the Isoproponal must be very small proportion and no trace of water.
Managed to misplace a screwdriver after one side of the road stop. Did I leave it in the engine bay, or on the verge?
Did not want to risk 2 hours of lean driving at moderate to high speed. Maybe the Aldon guys would have helped if I made it all the way.
So did a compression test and it's all good, Thought it might be HG between 1 & 2, which were running cool from IR thermometer at exhaust manifold.
Siphoned out both carbs fuel bowls, and measured how much in a jam jar, and they were about equal, so I think needle valves are not blocked closed.
Then looked at the plugs and 3&4 show white of lean but 1&2 are nearly normal to slight ash.
Rechecked the balance left/right and it's tipped towards 1&2, uncovering one more progression hole.
Had to take off the cable-mech to  see the throttle plate through the holes with a small torch.
With good access cleared out number 3 idle circuit and found a tiny sliver of black rubber.
Did it come from the o-ring or fuel line?
So small it blew away when I tried to pick it up to take a picture.
Refit cable-mech etc.
Drove and still rough and far too lean at cruise..
Tried fitting some big 48 idle jets, just in case there was still Isopropanol affecting the mixture.
That went real smooth, but obviously too rich - like 11:1 AFR or 9:1 at overrun.
Had to wind in mixture screws to nearly closed to reach 13.3:1 idle, black soot and moisture at tail pipe.
Switched back to the 43 idles and could not get cylinder 4 to change engine speed or influence AFR, unscrewing the mixture.
Removed and pulled the jet from the holder.
Looked through that idle jet up to the light and it was partly blocked with some yellow/grey/brown crud!
Fuel varnish?
Some carb cleaner spray and compressed air through that, refitted.
Yes, back to normal.
Balanced using vac gauges. Number 1 is still 2psi below the others but all at -13psi with some bypass valve opening.
Mixture around 14.4:1.
Wish I had been able to do all that during the week.
Disappointed I did not make it to the Rolling Road.
Time for a cup of tea.
  • Replies 71
  • Views 6.9k
  • My fuel filler was in a very sad state.  And since jokes with gasoline are bad, and there were about half of it in the tank, I restored the pipe with epoxy and fiberglass. That's what I got.
  • steveo3002
    steveo3002
    time to convert to mpi?
  • Yellow tinge is normal. It could be water at the bottom, I doubt its ethanol would separate like that -  it would doing that in the tank at tesco,    Is the filter at an angle - it could be
Think I might put a dab of paint on the left/right balance screw, so I can see if it moves, and I'm not tempted to mess with it and just mask a different problem.
There's a spring on it to keep it still I think, but the thread is quite coarse and it takes very little movement to  partly reveal a progression hole.
Idling on progression holes on one half of engine is not good. Surprised it didn't shake more. I suppose I mis-compensated with the mixture screws
for the starved cylinders.
Wonder if the AFR gauge log would reveal the imbalance? So busy with screwdrivers and siphon hoses and compressed air cans I forgot all about using the computer.
It's driving really well. Had a couple of stutters when I'd expect the accelerator pump to operate, then wheel spin. Think fuel and carbs are all clear.
But I finally filled the tank, and it sagged down and towards offside, disconnecting the fat breather hose which had no hoseclip, just push-to-fit..
I think tank is only held on to bodywork by the strap and front edge. I did not fit one nut at rear edge.
Might need to file or drill a hole in the tank seam to line it up with the stud.
It's a 42 litre tank in a 36 litre space.
The strap was not fully tight, because the rear edge was pressing on the threaded stud.
Drained 15 litres out of the tank. Used an axle stand to hold the car up and a hydraulic jack and piece of wood to push the existing seam hole over the stud.
Tightened the strap retaining nut fully home (it had 1/4inch to move ).
Realigned the filler and breather tubes.
Have ordered  an 11 to 13mm herbie clip to hold fat breather tube on the filler neck. No idea how you could tighten a jubilee clip or squeeze a self-tightening clip in that space.
Image result for herbie clip image
Was a bit worried about filing or drilling the tank with fuel in it, to be honest.
… and that clip is too small to lock by squeezing the ridged tongue into place.
Maybe a jubilee clip and 7mm flexidrive?
Sorted the last bit of stutter. Had sat in a queue with it idling and I could hear the faint pop of occasional lean, sure enough drive through the traffic lights and 18:1 on the AFR gauge and power down, rough sounding  at low to medium load.
Drove home with starter device assistance to try to stop any engine damage using the AFR gauge for feedback to push pull the "choke" cable as needed.
Reckon the main jets operate from 3800rpm or higher. Might try without them
I think the starter device mini carb feeds from very low in the well.
Wasted third of a can of carb cleaner on the idle passages and mixture screw and air bleed orifice and found nothing in the progression hole chamber that has acted as a sieve previously.
Suspected both cylinder 3 and 4, so took the carb cover off to check the needle valve and new filter around the banjo bolt. All clear.
Fuel level was a bit low in that carb. Found partial blockage at the T joint for carb feeding 1 and 2.
Inside of carb looking good after 2 and half years, though that might be the Seafoam.
But still could not get cylinder 4 to completely behave. I could get it to idle with good exhaust manifold temp and 14:3:1, go for a test drive and hit 18:1 on overrun and stayed there.
Even checked compression (just in case I had a burnt exhaust valve) and spark plug lead for that cylinder as it was not contributing to engine turning at all.
Suspected leak at brake servo take off, but, no, all good condition too from a Cold Start spray test.
Could feel the pulse of cylinder descending with intake valve open in the tube to the servo.
If there was a leak there would surely be no pulse.
Finally found tiny yellow fuel varnish flakes in the bottom of the that hole number 4 idle jet sits in at bottom of well. Sucked those out, reset mixture and re-balanced just bypass screws a tad
not the carb1/carb2 see-saw.
I reckon when you unscrew the idle jet stack to blow it clean anything partly blocking falls out, to be sucked up again next time there's high engine vacuum.
Idle jet is smallest hole so it's bound to be the point for any fuel blockage.
Air carried blockage could come in the top of the idle holder, not emerge from its emulsion holes and then sink inside the tube I suppose.
Got the bigger Herbie clip on. I hope I don't have to do that again for about another 10 years.
Had to push pipe from inside the car to get it far enough onto the 12mm side outlet, then get the clip over in opened position (like  a spiral)
then squeeze it together - took one hour and my left middle knuckle has no skin!
Wheel off and on, jacking, metal, ring around the rubber flap seal off and on. Torch that made no difference. Some snipe-nosed pliers for the Herbie clip  and molegrips on pipe inside the car helped.
Drove on the newly cleaned sparkplugs, and went lean and running on 3 cylinders after a roundabout.
Some idle jet crusty stuff. Limped home.
Got it to idle nearly smooth.
Suspect it is dirt washed off carb float chamber side walls. Lifted car left and right to simulate corners, then siphoned out both carbs, poured fuel through a sieve. Let sieve dry and found varnish!
so now letting carb chambers soak in Seafoam/petrol mix.
Siphoned out the Seafoam/petrol mix after overnight soak. It's golden coloured, like it dissolved years of petrol.
Took out all jets and mixture screws, which looked spotless.
Checked the fuel filter which only had a little dirt. Fuel from tank is much clearer pale yellow.
Refitted jets and mixture screws, maybe a bit too wide open to let any crap pass, and avoided the starter enrichment.
Was very hard to restart, occasional fire, actually got blue smoke back out of the carbs, let it rest, recharged the battery, and another set of clean plugs
(ones in engine were wet oily of none ignition),  and then vroom.
Revs, idles, pulls smoothly.
Reset mixture to 14.6:1 AFR with engine hot.
Feels like a new engine. It managed one roundabout no problem - I'll drive further tomorrow.
So drove front wheels on to ramps to try to replace the preheater from below, but only managed to remove old one. New preheater is a bit too big to fit without removing brake servo or carbs or getting longer pipework.
That meant rear of the carb float chamber got a good petrol washing too.
So. no big surprise when this morning got about 4 corners from home and went lean again.
Number 1 idle jet with a blockage that blowing would not dislodge - used a toothbrush bristle.
Ok, siphoned out, still quite golden, and back in with Seafoam/petrol from last time, but added through a filter paper in a cone.
I suppose I'll have to keep at it until no more crystals and/or it changes colour.
Seriously considering an ultrasonic cleaner or turning the car upside down and shaking it.
Maybe inserting siphon hose down main jet well is not going deep enough?
Yeah, there is fuel below number 37, main jet, and the pump diaphragm 30, is lower still.
Took carbs off and apart. This is the pump chamber.
scraped it out
and this is the carb in the ultrasonic cleaner.
before adding the fluid to heat up and buzz the dirt away.
saw this card...
Carbs back on, plumbed in and engine started. Going to let it sit and siphon one more time - see if there's anything above the pump diaphragm which I did not disassemble.
I did take out the drain valves, just left the membrane in place.
Well it evaporates faster and is light yellow but less golden.
Think it drives okay when warm too, idle is about 14.9:1. Might close down the one bypass screw I opened on cylinder 2 to get equal vacuum.
The 31mm chokes have added a slight 2500rpm hesitation. Could be the pump circuit with some crud still, or 33 pumps undersized now.
Need to look at the AFR log matched to video and revs...
About 0.6 AFR leaner with the 31mm chokes. So 12.6 to 13.2:1 at hard acceleration which feels good and 15.4 to 16.4 at light cruise. That's possibly too lean even with my compression ratio.
In slightly better weather plus a warm air pipe the 2500rpm hesitation has gone, might have been fuel pooling in inlet runner for lack of warmth instead of staying in a emulsified state.
But anyway, I'm going to try switching away from 5% Ethanol Momentum 99 and lose some ignition advance headroom if I have to.
And if ever the car needs to sit for a few months I'm going to drain the carbs and add something like FuelFit to petrol in the tank.
Oh yeah, starting is still a bit hit and miss from cold in the wet morning without the preheater.
Dunno if that's just damp on electrics or the cleaned carbs and slightly bigger chokes.
The starter circuit is downstream of throttle flap so surely the chokes have hardly any bearing.
But my liner tube might be disrupting flow a bit?
Took 2 attempts for journey home this evening.
Read the Passini chapter on Weber starting devices DCOE section.
Either pump the pedal or use the starter circuit so maximum suction on starter's pipes.
Started first time if don't touch accel pedal while cranking.
Can do 2 or 3 press to floor of gas pedal to prime beforehand.
DHLA has better starter than DCOE..
Hopefully weather will stay warm now.
Warm and wet. No starting problems so far with new no accel pedal while cranking technique, but a few cut-outs, with instant restart.
Usually when come to a complete stop so high vacuum, poor cylinder filling.
Now on half Momentum 99 half unleaded 95 so approx 2.5% ethanol.
Think it is leaning when cuts at idle so maybe more blockage from above the pump membrane reaching an idle jet or several ?
Or the ignition timing advance needs more than I added for 99octane.
I'll check the jets. Need to count how far in the mixture screws are.
I moved to 45 idles (from 43) for the 31mm chokes and the fuel and that's shifted moderate cruise AFR from low 16s to 14s. Light cruise is 15.3.
Not checked the jets because it is perfect while in motion.
Stil got a cut-out after driving 15 miles. Headed to lean at standstill after gentle descent. No racing like vacuum leak.
Maybe the warm air needs a hot/cold control flap. Could it possibly be too warm in 19c ambient? Only a little damp.
Surely not. No-one has carb coolers in the Australian outback.
Heated air more easily sucked in through foam of Dergo filters than wall of trumpets and foam carb socks?
Surely any heat would richen mixture due to lower density less oxygen.
Bah, a few of the top segments in the LCD of my IR thermometer have stopped working.
Warm air pipe was 65 ish, carbs were 27 (?), block was 90, exhaust manifold over 250.
Ah, the warm air pipe appears to be in light contact with fuel line at some points post fuel pump, pushed forward by the Dergo tubes. That's not good, it could form a vapour lock and not fill the float chamber, when needle valve opens.
Which would lean then cut.
So I'll try a blend of cold and hot air, not just hot.
So hot from exhaust manifold and cold from behind headlight combined has improved matters. 🤞
Going to check whether heat insulation around fuel pipe changes anything. 15mm foam tubing a mere 85p from Screwfix.
Yes, that sorted it.
Feels better at low revs... pickup, pulling away.
Only needed half the foam tube so under 50p.
Looks rather ugly. Wonder what engine bay heat will do to it? Think Climaflex tube must be good for nearly 100C if usable at boiler outlet.
I suppose unleaded 95 is more volatile than momentum 99. So easier to turn into vapour in the unintentionally warmed fuel pipe.
So just cold air feed for summer? Make the thermo valve and vac driven trapdoor flap work so switches to cooler air when engine intake warm?
It was the vacuum tubes gone porous. Felt sticky and had changed colour to brown.
