Mk2f coupe dash pod removal.
Hi all
so I need to remove the dash in my polo. It has what appear to be radio key holes on either side. I’ve inserted the keys but can’t get the damned thing to budge. Are there some additional screws? Many thanks rich
  • Views 943
On a mk2f
Long flat head screw driver and a torch
Take light switch out and look in, the is a 'u' shaped clip on the side facing you, the feet need to be pushed in to come forward so do one and pull the clocks to hold it and do the other. Then take the radio out and do the same again
Edited by kiran_182
