power steering fluid change polo 6N
How do you open the pas fluid reseivour? polo 6n afh
theres a green rubber top with a 8mm groove in.
do you require a special tool? I stuck an allen key into and tried to turn it anti clock wise but feel like i'm going to rip the groove
won't budge.
is it anti clock wise or do you pull it off?
https://www.autoparts24.co.uk/item/G_0001_0037281PI0100/
  • Views 1.5k
I put a screwdriver shaft in horizontally and unscrewed anti-clockwise. (on a skoda octavia, but looks the same).
Old plastic and cold weather is always a worry.
yeah old plastic all right and cold weather. shall i get some heat on it?
hairdryer?
I just put a gardening glove on for added friction, seems to work
