Polo 6n - Removing cabin filter housing
I replaced the cabin filter earlier this week and noticed a lot of gunk in the scuttle panel area.  I therefore want to remove the plastic housing the filter sits in and clean it thoroughly.
There are two plastic nuts I have removed but the box will simply not budge.  What am I missing?
On a  '97 Polo 6N 2-door.
  • Views 1.6k
27 minutes ago, nige8021 said:
https://volkswagen.7zap.com/en/rdw/polo+derby+vento-ind/po/1997-158/8/819-819020/#21  it indicates there are 5 nuts to be released before the housing can be removed from the #2 below
Thanks, that is very helpful.
I'm amazed I missed 3 nuts though, I can only assume they're caked under some of the gunk I mentioned in the opening post.  However, I didn't think it was THAT bad!
Edited by PoloMM
Utterly baffled now.  There are definitely only two nuts at the top. Surely there aren't another 3 hidden behind the wheel arch. They wouldn't make it that hard to remove would they?!
Managed to remove it.  Only two nuts but the seal did need a bit of persuasion.
Only I snapped one of the chassis mounted bolts when reinstalling 😠
