6n2 clock spring, steering squeak, lube?
Hello all,
Main question: What type of grease for steering clock spring? Does it need to be conductive? Is there such a thing? Seem to remember the contact area is on the indicator stalk  side somewhere?
Had clock spring replaced many years back. Getting a slight squeak from somewhere on steering so want to catch it with some lubrication if that's all it needs.
Rather than take the steering off unnecessarily  I was gonna just put some grease in the gap with a toothpick and see if that does the trick.
Many thanks in advance,
Simon
Edited by cosaw
Corrections.
  • Views 773
General purpose silicon grease should do the trick in either the solid or spray form
Thanks nige - that's great! Will give it a try and the good thing is I actually have some for a change!
Edited by cosaw
