6N2 AVY crankshaft sensor plug location
Hi everyone!
I had problems with starting the engine, and performance issues, and I realized the crankshaft position sensor was unplugged. Where should I plug the sensor in? I found the sensor and the wire, but idk where the other end goes....
I couldn't find any info about this, just the sensor location...
Thanks in advance!
  • Views 4.5k
  • Back of the engine under the inlet manifold by the joint between the engine and gearbox
