Smokey misfire
The polo has developed a smokey misfire quite suddenly
This one is taken about 10 seconds after the garage was filled with smoke, oil water levels appeared to be normal
This second vid is a after a large bang trying to start, you can see the wall is black from the last few goes
Seen anything like that before?
  • Views 1k
does it smell of fuel or oil...id be suspecting something bad
compression test /check cam belt timing and report back
Comp 12 13 13 13
hmm maybe an inj stuck open ?  had any earthing issues?
does it smell of petrol?
Think the smell is fuel rather than oil
