dergo air filters
Anyone come across Dergo filters before?
I can only find a few images for Fiat 1100 twin choke carb filters, but no company history or other information.
The filter element looks like scrunched up wire wool. I'm sure it flows better than paper element.  I can imagine it stopping insects and dandelion seeds but not being as effective as K&N oiled cloth or polymer coated Ramair foam
to keep roadspray suspended rock-salt, grit, tyre rubber, diesel soot and pothole dirt out.
I want a filter that covers the DHLA idle circuit, which trumpets plus foam socks do not. And found some Dergo for Alfa twin carb filters.
imageproxy.php?img=&key=a31c107f08879a83imageproxy.php?img=&key=a31c107f08879a83dergo-filters.thumb.jpg.960694e27ae88e0f50b581c64889e12f.jpgdergo-filters-open.thumb.jpg.df41bf9673ed798d14012ece329c77b9.jpg
In a bit of a mess...
This is the wire wool construction
You can see I'm pushing it out from below with a sheet of Ramair foam.
Fitted longer m5 spacers and new m6 studs and nuts.
Clean up the cases
Should keep carbs clean and shortens the inlet.
Can't decide about the vacuum and breather ports.
Blank them or use with Y-piece from the breather pod on block?
  • Replies 32
  • Views 2.9k
Looks like they were black
See the source image
on a weber 32iba … with some ingenuity!
Ram-air material looks like a good upgrade  - I can see you have spaced them out the cover from the base plate - how much space have you given between trumpet & cover?
The recommended minimum is 25mm
I'll have to measure. My existing trumpets are 45mm, and there's 27mm to bulkhead for tightest fit.
There's no trumpets inside the filters (yet).
Trying for very short inlet tract. Wondering about ITG stubbies, or some half donuts of nitrile or viton with 40mm internal diameter.
Might chop some old bike carb trumpets or get creative with fibreglass,
Proximity of trumpet to firewall has worried me.
One has 27mm gap.
Each Dergo now measures 38mm from front to back inside faces. And entire filter is 69mm at deepest point.
Mostly it is 50mm deep and nuts are 5mm so there should be clearance to attach them 🙂
I think I have 72mm from back of the carbs to the firewall at thinnest section, so it might
need to some "percussive adjustment" if things are too close for engine rock, if I cannot simply
turn the rear plates upside down to mind the gap.
With no trumpets inside I reckon I'm just adding 5mm to inlet tract which I think is
92+65+112+5 to give 274mm which matches 3rd harmonic Helmholtz at 6400rpm
with ~270 duration cam
according to
https://exx.se/techinfo/runners/runners.html
or 3rd Helmholtz at 7000rpm using Daipipes which reckons I only get weaker 5th Harmonic with 311mm
inlet that existing 45mm trumpets provide.
Alfa Romeo did not have trumpets inside the Dergos and were only ~26mm deep front to back inside faces.
(I'm pretty sure I added 12mm spacers)
Going to try chopping four of these down to size.
Chopped the toy trumpets (after checking petrol and heat does not dissolve them)... a bit too deep, but adjustment possible.
I decided to cap the random breather and inlet holes for now.
Test fit... won't go over the inlet studs without severe bulkhead bashing.
I've seen some studs with inner hex fitment  before so could maybe fit through carb holes against the manifold facings.
Misab plates will be awkward
Volksbolts do the inner hex m8 studs - currently out of stock. But I usually fit trumpets once carbs in place - so tried with Dergo partially disassembled a few spacers removed.
That works on the spacious side of the bay. It could work on the tighter section too. Right, in with the 31mm chokes. Don't want to do this too often.
Rain clouds approaching.
Don't think there's anyway I can get the trumpets in and fit / remove spacers.
I'm using an 8mm ratchet spanner whose head would be obscured from sight and have only limited movement.
The red trumpets are probably too close to rear of filter wall at current depth in any case, so I can take my time shortening them.
Nothing for it, got to break the cardinal rule of carb experimentation.
  • Change one thing at a time
So shorter inlet tract, maybe larger filter surface area, no trumpets - in fact a hard step from 45mm to 40mm, 32mm chokes but with a laminar-flow destroying liner tube making for 31mm- ish chokes.
Lost a nut while trying to fit the most awkward one. Searched with a magnet and found the crinkle washer in a crevice, but the nut is brass...
Chopped down a spare spacer instead and fitted to the car.
One misab plate was annoying. And I can't use a long straight 1/4" drive on the carb to inlet manifold stud nuts because the filter front plate gets in the way.
Not re-started or driven yet. Should be quieter than the trumpet + socks.
Found 2 spare nuts like the one I lost. Can't decide whether it is worth the pain to fit it to be like the rest.
  • on the negative side - might lose it too
  • on the plus side - be easier at next removal
Described as black stainless steel cap nut, but my magnet that can lift cutlery does not attract it.
Gave up trying to swap it. I can get better  access by removing a grommet in bulkhead AND raising that carb, which means undoing 4 stud nuts and unsealing the Misab plates.
Found some other trumpets that could be cut to size.
Only 38x more expensive than the toy ones.
https://www.youtube.com/watch?v=YNamh_4MwVI
Nice colours though, and golf ball surface.
They like non-laminar flow.
Today 84% humidity + 10deg C dew point at 13deg C ambient equals carb icing.
Going to put the warmed air intake back on.
In June, where's the gulf stream? Climate catastrophe.
Engine losing power running rough then stall after high vacuum. Sit for 3 minutes and it would restart.
It's icing or the Hall sender.
Warm air tube from exhaust manifold to the Dergo's helped a lot.
Not the Hall sender. No stumbles at all with warm air tube. Icing or condensing fuel on bottom of an inlet runner.
They are quieter than trumpets but not much at full throttle.
  • 6 years later...
I put some short 3d printed trumpets inside in petrol proof ABS.
92+65+112+25 = 294mm which gives 3rd order Helmholtz at 5700rpm with ~270 cam.
And the AEM says I'm hitting as rich as 11.4 at hard acceleration 5500 to 6500rpm when manifold pressure goes +ve 0.22psi.
So bigger air correctors than 182.5 perhaps?
Still need accurate revs capture.
Changed to 200 main air correctors (in .7 tubes) from the 182.5.
Still managing 11.7 at high revs.
Trying 210 air correctors.
That got to 12.1:1.
Went to reduce the main jets, found i already had.
98/7772.7/210.
Might try the holey .10 emulsions.
Can also reach high 12s at 2700rpm, which is before the mains start, just up slight incline.
But nice 14s at 2000rpm.
Gone down to 43 in the 7850.3 holder.
It's almost as though there's very little ethanol in the BP Ultimate 97... pump definitely has E5 label.
Aha,
https://www.nortonownersclub.org/forum/bp-fuel-and-ethanol
Well that explains a lot. And why the garage suggested it to help pass the emissions test. My ignition map compensates timing from the MAP sensor, but the
carb jets don't know.
14p per litre more than Momentum99, so about 10% more expensive. Nice to be driving it again, let's see what Chancellor does to fuel tax.
