engine struggling to turn
yes. same for alternator.
  • Replies 35
  • Views 3.4k
  • caretakerplus
    caretakerplus
    Just because a battery comes with a higher Amp Hour capacity (To put this in very crude terms, this means a larger bucket full of electricity!) it doesn't necessarily follow that it can provide a high
  • starting takes a lot, I reckon on 15- 20 minutes driving to replace what is lost. Charge it up overnight? Should be fine if you can turn it by hand with socket on crank pulley. Loosen spark
  • caretakerplus
    caretakerplus
    Even a battery that is 'past its best' may well still show 12.2 volts without a load on it. If you wish to test your battery when it is fully charged, connect your multimeter across the battery t
right... so no voltage drops on those cables. going to have to do what dvderlm said ten times and take it for a long drive 15 minutes minimum and monitor the voltage drop on the gauge inside cab.
then do voltage drop tests again when cables are hot.
  • @ dvderlm still didnt go lol
on further  inspection found smallish break in ground cable from negative battery to gearbox
does starter motor require more amp when it's hot. got a feeling it's tryna draw more wattage when warm.
i doubt a little break like this can cause this. 20-25% of it is broken.
How far did you drive? At how much load?
Yeah, that cable won't help the electrons flow reducing current.  Fit a fat jump lead as extra earth temporarily, see if that helps.
i didnt. when i saw cable stayed in. - ill just order another cable.
where's your sense of adventure?
I'm kidding, you are probably more sensible than me.
There's more friction when hot, when engine not broken in and still tight. Rings sliding in the bores which get smaller as block metal expands, so engine compresses to higher pressure, it's going to need more current to turn over and reach 250 to 500rpm firing speed and have enough volts to spark.
it's not that, just survival skills are shit lol
replaced ground cable from negative battery to gearbox and drove car 5 minutes, stopped, and started, drove another 5 minutes, stopped  , and started up again.
so working now. looks like the starter was trying to draw more power when hot but little break in cable wasnt allowing it too.
still got this hot start problem. any chance of using a starter motor more powerful than 1.1KW?
