Jump to content
Recommended Posts
Eviljohn
Hi polo people. Hope you're all well and good.
After a good few years, i've finally got the cash in the right place and right time to invest in a H&R cup kit for my bready. If it's possible, i'm hoping to get some pointers from anyone who has already done this swap.
I did change the suspension on a previous bready from stock to Bilstein B4's and Eibach springs so remember most of the process. Also have the step-by-step guide from the faq section bookmarked and a Haynes at the ready.
Info i'm hoping to get is:
Last time i did it, couldn't find a stock set of bump stops. I'd quite like to have as many parts as i can get handy so it all gets done as quickly as possible. I do have help but it's volunteered. Can anyone advise on where to get stock ones or something that will fit closely?
Do i need to change top mounts? I honestly don't remember if i did it last time.
Am i right in thinking i can leave the spacer out on the rears to get the extra drop in ride height?
Will i need to have some 2p's handy to compensate for a gap in the struts?
Any other tips or things to look out for would be greatly appreciated.
Thanks for stopping by and as always. Thank you for any xp you guys and girls can leave.
Take it easy.
Share this post
Link to post
Share on other sites
dvderlm
I've seen standard rear bump stops on ebay
eg
https://www.ebay.co.uk/itm/VW-1981-1994-Passat-Polo-Rear-Shock-Absorber-Bump-stop-Kit-357598131S/152953689365
The listing covers loads of other models.
May as well do top mounts while you are there. You would remember old ones looking like squashed donuts if you did change them. If they are 35 years old like the car I'm amazed they have not collapsed.
Share this post
Link to post
Eviljohn
Cool. Thanks dude.
I don't know exactly when the fronts were last done on this one but i'm guessing last couple of years. Previous owner said it's running on stock shocks and shorter springs. I honestly don't know if they're chopped standard springs. Wouldn't surprise me if they are given the other things i've had to fix since i got this one! I do know it's crashy as hell and sucks.
I've already had arb blocks fitted. Was advised to get bushes replaced and as it was already lowered, figured i'd just get that done.
Share this post
Link to post
dvderlm
H&R will be a bit bouncy, but that's better than crashy ride.
Special tool for the nuts on top of the front struts, or molegrips?
Share this post
Link to post
Eviljohn
Got molegrips. I remember that from last time for sure! Think i have a spare set of castle nuts kickin around the shed as well.
There are no bump stops on the front are there? Just the top mounts that will need renewing?
Share this post
Link to post
Eviljohn
Right. Pretty sure i'm ready. Got new bump stops, new top mounts, H&R kit comes with it's own bolts and the bolts in place on front don't have castle nuts so no donkin about with that!
Has anyone had any issues with the H&R front shocks being too short for the struts? Do i need to have some 2p's ready to fill the gaps? I did with bilstein b4's on a previous car.
Thanks for any xp peeps.
Share this post
Link to post
kwijibo_coupe
The H&R front shocks fit perfectly in the struts, H&R supply their own new strut caps too which is nice. No 2p needed on the ones I fitted last, but admittedly I haven't driven on them yet so can't say if they knock at all. But they feel solid in the strut.
Share this post
Link to post
Eviljohn
That's good to know. Thank you.
Share this post
Link to post
1vw2many
Hi the same kit I fitted without the 2p and have had no trouble at all. Am very pleased with them and a good ride. Good luck and enjoy.
Share this post
Link to post
Eviljohn
Fitted today. Saved myself 8p! Came armed with 2p's but didn't use them. Only had chance to go round the block but felt like night and day compared to what was in place! OE boge shocks on front with springs that were same size as the H&R ones that replaced them. Already had Bilstein b4's and Eibach springs on the back. Takin it for a long run back tomorrow so will get to try it out for sure. Very much looking forward to it.
Thanks for the info dudes. Really appreciate it.
Share this post
Link to post
Eviljohn
Massive difference! Actually fun to drive again!
Wish i'd done this a long time ago. Left the spacers on when we fitted the rears. Thought i may have clearance issues otherwise. Very happy with it though.
Share this post
Link to post
POlliffe22
got this kit on mine and love it. front springs do get coil bound and can hear clattering at low speed (i am led to believe this is because they use progressive springs) but car apparently corners almost dead flat (my mates tell me when following) with 165/60/14 nankang as1 when going through the brecon beacons at speeds that pc plod would have something to say about.I also find them very comfy on the motorway even all day hundreds of miles.
Share this post
Link to post
Eviljohn
I did an hour on the motorway day after i fitted them. Only issue were my seats. But they look like they've been fingered by Wolverine. I have noticed MUCH less roll. Already had arb blocks in place. Even over speed bumps. The only rattles are from rear speaker surrounds. Previous owner over tightened the screws that hold them in place. Broke the plastic around the screws so little rattle over lumps and bumps.
Really pleased with this kit. Will be recommending it to anyone who will listen.
  • Like 1
Share this post
Link to post
kwijibo_coupe
The H&R kit is easily the best budget kit for these cars. Young kids these days will easily spend £500 just to get the cheapest height adjustable coilovers to be scene. Trying to get across to them that you can save £200 and buy a fixed height kit that is better in every way is hard work.
  • Like 1
Share this post
Link to post
Eviljohn
Am i right in thinking that it's a lot of effort to set up coilovers properly? Get each corner balanced correctly and all that jazz?
Are coilovers more suited for track cars?
Share this post
Link to post
POlliffe22
You can just set them up for ride height and assuming they have sensible spring and damping rate they will drive the same as springs and shocks. However you CAN cornerweight the car to improve load balance on the 4 tyres which can help when really pushing hard.
Share this post
Link to post
Eviljohn
I see. Good shout if you use your car for road and track.
Share this post
Link to post
Bevlesskeg
I tried the H&R kit 60/40, i personally found it too harsh around my local area especially on the front. They do a 35/35 kit too right? I can imagine that being better on roads.
Share this post
Link to post
Eviljohn
I had Bilstein B4's and Eibach springs on a previous polo that did about that amount of lowering. Can highly recommend that set up. Much cheaper than the H&R.
Share this post
Link to post
PollyMk2
About to fit H&R Cup Kit to my Mk2 coupe - I want to replace some other components especially top mounts and wondered if anyone could show me what exactly to buy and from where?
Share this post
Link to post
steveo3002
https://www.ebay.co.uk/itm/VW-POLO-MK2-MK3-G40-TOP-MOUNT-KIT-STRUT-MOUNT-C86/221085795525?fits=Model%3APolo&epid=2208876798&hash=item3379bd84c5:g:EVQAAOSwiVFbpKRp
  • Thanks 1
Share this post
Link to post
Eviljohn
If memory serves, pretty sure i just got oe top mounts. Just googled it and snatched up what i could find.
Share this post
Link to post
PollyMk2
Thanks guys - I take it I need 2? 🤦‍♂️
I’ll pop some pics up when she’s on the new set up!
Share this post
Link to post
steveo3002
yeah one for each front side
  • Thanks 1
Share this post
Link to post
Eviljohn
Couple things i found on my mk2 bready, not sure what is transferrable to coupe.
Needed a swan neck spanner, (19mm i think, anyone confirm that?) So you can fit a hex key down middle, to stop strut from spinning with top nut while you loosen/remove top nut.
Also had castle nuts on front struts when i did it on my other bready. Someone had already done me the favour of removing them from this one by the time i did it.
Not sure if you need replacement bump stops on coupe's. Anyone confirm?
Front struts on bready had goo inside them. Does coupe? Because stinky=gloves.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
