stub axle bolts polo 6n/6n2 rear disc conversion
m10 x 32 are the rear stub axle bolts: N  90758901. they are 4 on each side
is the pitch 1.25 or 1.5 on these bolts?
for some reason the bolts came out okay with the impact gun on both sides of the rear axle but on the left side of the axle all 4 of the bolts are hard to go back in unless i use a impact gunon full setting then they go in.
thinking of putting a m10 tap through. threads look allright in axle but on the bolt kind of sheers/brightens them up.
but with an impact gun id get them in. once thier in , never comeing back out as im doing rear disc conversion.
dont wanna mess things up further by using the tap. difficult one because i think max torque on those bolts are 50nm
ive ordered some new bolts also, should have them on wednesday. might just put oil on them and use impact gun.
  • Views 1.4k
Popular Days
they are m10 x 1.5 pitch and have re-tapped/ cleaned the threads out.
jut could with knowning what nm stub axle is. 50nm?
