balance weights hitting rear caliper
just done the rear brake disc conversion to the 6N1 and using my light weight 14inch alloys.
paint calipers job lot and realised balance weights hit caliper when doubled up.
the single ones go past just but the ones that are doubled up hit. 1 inch from the balance weights the alloy dips in shape. can the balance weighs be put there or re-done where they are by just using single weights?
dont fancy changing alloys. wouldn't have done the conversion if alloys had to be changed. i did semi check all of this before painting calipers but obviously didn't spin the wheel fully around to where the weights were.
  • Views 826
  • steveo3002
    steveo3002
    put the weights side by side or get bang on ones if the wheel style allows it
