Mk2f 91 GT water pump help
Hi before I bolt up new febi water pump kit  just checking I don't need any additional sealer on the face of the pump itself ?
I assume we only use the rubber sealing ring that comes with the kit ?
Many thanks.
  • Views 635
  • steveo3002
    steveo3002
    just a new oring ...no sealant needed , would be wise to check the block isnt rusted /scaly where it seats , wire brush it if need be
Yeah, helps to descale the block too, get the right orentation on the pump too so you can tighten it with the notches
So what sealing compound do I need ?
Edited by 1vw2many
