Distributor wiring
Evening all,
I want to bench run my 1100 hb engine, but forgot where the wire from the condenser on vac adv dizzy goes, is it to negative?
  • Views 703
  • caretakerplus
    caretakerplus
    'Yes' is the answer. But (why is there always a 'but') - Don't run your engine without it being connected to the radiator and having coolant in it (plain water will do). Without coolant, local ho
It goes to the connection on the contact breaker the same as the wie that goes to the coil , it's to suppress the sparking across the points as they open
Sorry may of worded it wrong, (more than likely it's me being retarded) it's this connection arrowed, to negative on coil.
Edited by littler52
Without coolant, local hotspots can develop VERY quickly, leading to all sorts of problems caused by uneven expansion.
Regards
Cheers,
It will have all lubes and coolant in before being test run on bench, was just unsure of dizzy wiring (used to 3 pin connection with plug and play loom)
Battery positive (+) to coil positive (+) via a switch if you wish.
Coil negative (-) to distributor as your arrow.
It might be more convenient to pick up the positive feed for the coil from starter motor main terminal.
Regards
