Rear Passenger & Right Number Plate light
Hi Guys,
I need a little help please, today i took my car to the car wash and on the way back home i got a warning light, it was to do with lights not working.
i checked around and found my rear driver-side number plate light out, so planned to change it tomorrow, tonight when i got info the car i realised my passenger rear light was out also.
I'm a little bit thick when it comes to things like this but to sounds like a fuse as apposed to light bulbs.
Its a 2011 Polo 1.2 D,  any ideas, seems a bit odd its to different lights on the same fuse, or could it be different fuses blown because of water from car wash?
Any help including fuses numbers to check would be great fully received.
  • Views 1k
First Welcome to the forum.
The number plate lights both come from the same fuse #7 so if one is not working it can only be the bulb/holder
If the sidelight in the passenger headlight is working then it is the rear bulb failed
