Mk2 polo 4 to 5 speed conversion
Hey guys I've got a mk2 1043 4 speed. Im looking to do a AFH conversion along with a 5 speed.
I've gathered that most 5 speed mk3 boxes will fit if I get everything with it (linkage, clutch, starter etc). Will i also need the gearbox mount?
Im in New Zealand where mk2/mk3s aren't very common. Hoping for some advice before I dive into it.
Cheers Jacob!
  • Views 1k
  • Easiest with 5 speed top-mount, though you could make one if you can weld. See the picture. 4 speed has 3 vertical bolts. 5 speed has 2 horizontal.   https://volkswagen.7zap.c
See the picture.
https://volkswagen.7zap.com/en/rdw/polo+derby+vento-ind/po/1984-9/3/300-26000/#1
Get a 5-speed ARB to clear the end-plate.
If lowering also
Consider g-laderseite ARB bushes or similar to pull ARB forwards.
Stops it touching gearbox and improved caster angle for nicer cornering.
I've been offered a 6n2 gti. I can pull the entire engine/box but I'm unsure if the ARC engine is a good swap choice.
ARC has been done. If you keep the ECU you can use the VVT as well.
You'll need to swap the gearbox output flanges from you're 4 speed into the 5 speed that comes with the engine. I believe these grearboxes fit, but I could bee wrong. You'll need a mk2/2f 5 speed mount however
