ACR/AVY torque settings
I'm after the torque settings for the ACR/AVY direct drive oil pump to block bolts.
  • Views 637
  • Lightly oil sealing lip of oil pump oil seal.
  • ‒ Guide oil pump carefully onto crankshaft polygon cams.
  • ‒ Align inner rotor to crankshaft polygon cams by turning slightly if necessary.
  • ‒ Then slide oil pump carefully onto guide pins.
  • ‒ Secure oil pump with new bolts.
    Tightening torque: 10 Nm
Thank you, iv not been able to find them anywhere.
