6n2 1.4 AUD engine - P0343 code
Evening all,
I have a 2001 Polo, 1.4 8v AUD engine that won’t start. Turns over fine but just won’t start.
VCDS shows a P0343 code - camshaft position sensor. The sensor was replaced and didn’t solve the issue.
I have continuity on 2 of the 3 wires from the cps plug to the ecu plug. Does anyone know which colour wire does what and whether all 3 do go straight to the ecu?
Thanks.
  • Views 941
First Welcome to the forum.
Cam position sensor G40
Pin 1 Green/Lilac to ECU pin 62 Supply (5Vdc)
Pin 2 Yellow/Black to ECU pin 60 Signal
Pin 3 Brown/Yellow Ground ECU pin 54
I see you have put your car as a MK3F on this forum the 6N2 is considered a MK5
Great, thank you.
It was the green/lilac one with no continuity so assuming that’s the problem.
Also profile now changed!
Cheers.
