9N3 Front Electric Windows Not Working
Hi all
I have a 2008 VW Polo 9n3 1.2 5Dr which has only electric windows in the front. A few weeks ago they started to play up only working intermittently now to cease to working at all via any of the windows switches in both the passenger door and driver’s door. Both windows still go up and down by holding the key in either the passenger/driver's door's (lazy locking/unlocking).
What I have tried so far
1.      Checked all possible fuses
2.      Checked the grounds at the window motors/switches
3.      Checked the wires running from the a pillar to drivers door for breaks
4.      Check electrical connectors in a pillar and door for dampness none found
5.      Run full VCDS diagnostics scan no faults found
6.      Took a look in measuring blocks and found that window Regulator (drivers Door) is not installed
7.      Tried to recode the central convince control module from code (00019) tried the following codes 00064,00016,000259,00067 and from some of the code’s i got in measuring blocks CTRL Module Does not Respond
Hope this all makes sense and any help would be appreciated.
I have attach a log and some screen shots of VCDS.
1325692555_IMG_20200202_1224581.thumb.jpg.b1792d93e145d04dfbc7944464229f32.jpg1135662640_IMG_20200202_1225011.thumb.jpg.ab7a9f36fdba6c979da6801411d3e44c.jpg707444983_IMG_20200202_1225051.thumb.jpg.ab103b6f4661c9f214e4eae7d7ed1554.jpgdiffent coding to original
Sunday,02,February,2020,12:31:34:13167
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ9NZ8Y163229   License Plate:
Mileage: 90580km-56283mi   Repair Order:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ8Y163229   Mileage: 90580km-56283miles
Address 01: Engine        Labels: 03E-906-033-AZQ.lbl
   Part No: 03E 906 023 B
   Component: SIMOS91 1.2l 4V     1891
   Revision: --H04---    Serial number: VWZ7Z0H6450996
   Coding: 0000071
   Shop #: WSC 00788 785 00200
   VCID: 1E65D9121CA4E307DBB-5184
No fault code found.
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
   Part No SW: 6Q0 907 379 AF    HW: 6Q0 907 379 AF
   Component: ABS 8.0 front   H05 0002
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0002085
   VCID: 015F826E8D1A3CFFC69-50F4
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Q0 820 045
   Component: Klimaanlage        X0850
   VCID: 6A8DC5C2956CDFA7773-50F4
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 F
   Component: 0009 BN-SG.         2S36
   Coding: 25742
   Shop #: WSC 00788
   VCID: 3E253992B9648307FBB-50F4
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 K
   Component: 18 AIRBAG VW51 0P   0010
   Coding: 12600
   Shop #: WSC 00788
   VCID: 2C0103DA5F18019745F-50F4
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 903 J
   Component: KOMBIINSTRUMENT VDO V06
   Coding: 01431
   Shop #: WSC 00445
   VCID: 38292F8A9B40BD37317-50F4
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 01K1 GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 00788
   VCID: 70B9D7AAB3B02577397-50F4
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER VDO V06
   Coding: 01431
   Shop #: WSC 00445
   WVWZZZ9NZ8Y163229     VWZ7Z0H6450996
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 10110
   Shop #: WSC 00000
   VCID: 2F3B14D66E0E7A8F60D-50F4
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 6Q0 959 433 H
   Component: 1N Komfortgerát     0002
   Coding: 00019
   Shop #: WSC 00788
   VCID: 40D9476AC390F5F7897-4B3C
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 6Q0 035 152 E    HW: 6Q0 035 152 E
   Component: Radio 9NK           0004
   Revision: 00001000    Serial number: VWZ4Z4GD070429
   Coding: 0020202
   VCID: 2C0103DA5A18019745F-50F4
End----(Elapsed Time: 02:29, VBatt start/end: 13.6V/13.6V. VIgn 0.0V)------
Edited by Ryanpolley
  • 2 years later...
  • Views 3.6k
Hello!
I'm having the exact same problem - did you ever work out the issue? 🤞
What year is the car @Jodes180, and does 'exact same problem' include the windows working via key turned/held turned in door?
