Hi-torque starter on ARC block
Iv got an Hi-torque starter off here and I'm fitting it on an ARC but iv read that the starter needs rotating to fit, does anyone have information on this?
  • Views 591
is standard starter not strong enough to turn it over?
im having same probs with 1.6 conversion.
looking for high torque starter for AFH block
If it's a standard AFH then depends on what flywheel your using aswel, if it's a hybrid with a MK2/mk2f then you'll need a stronger starter motor, either Hi-torque one or a 2f diesel one will do but you'll only get one from Germany
