6n2 electric trottle body to cable
Hi,
I woud like to change entire trottle body on my AUB with one from AFH.
AUB has electric gas pedal, AHF has a wire and the connector for TPS in different.
Has any of you did this?
  • Views 660
  • Thanks! Because it is for a rally/hillclimb car and it's not as responsive like cable trottle. I have another pedal box and the ECU is not standard
First Welcome to the forum.
Why do you want to change the throttle body to a cable one ? as this will also mean a new pedal box and the engine ECU probably will not work properly with the older cable system
Thanks!
