MK1 wiring help needed
I’m on rebuilding a mk1 895cc polo engine (1978) as a project and the engine wiring harness did not come with it so if anyone could tell me the bare minimum of wires I’ll need to get it running that would be great, I also have a few boxes of parts and trim that I won’t need if anyone is interested in buying some just let me know, thanks
Edited by Martin8989
  • Replies 16
  • Views 1.3k
If it's still on points ignition, I'd have thought you'd be able to get away with earths, a feed to the coil, HT's, a decent supply to the starter and something to feed the solenoid with while cranking.
I link I've actually got a full mk1 engine loom, only catch is it's at mum and dad's and they're in isolation, so I won't be able to send it any time soon.
Hi,thanks for the reply,it is still on points I will try wire it how you said but I would be interested in buying your loom when the lockdown is over with,thanks
I’m also wanting a coil and ht leads if you have any forsale cheers
You might want to make out a Wanted advert in our free to use classified section https://www.clubpolo.co.uk/classifieds/category/8-wanted/
If I've got any, they'll easily be 20 years old, so it's worth buying new. They're a fairly generic parts and do wear out, so wouldn't be expensive
Ok cheers I’ll have a google just didn’t know if they had to be a certain voltage and length
Ignition leads :
M4 connectors.
38 cm, 51cm, 52cm, 59cm for mk1/audi 50
(33cm, 45cm, 47cm, 54cm for mk2 due to 90degree bend at dizzy) and king lead long enough to reach the distributor cap from the coil 50cm?
I guess 1kiloohm RF suppressor for the radio in the plug leads.
Coil should have 1.7 to 2.1ohms primary and 7kiloohms to 12kiloohms secondary resistance for points.
It'll be about 15 kilovolts in the HT circuit. Don't try to measure it.
The condensor might be worth replacing if the points look burnt, or you can see sparks at the points when cranking.
Don't forget earth straps from front mount to wing and gearbox to coil mount bolt, for example.
Battery earth seems better protected than engine bay ones.
Edited by dvderlm
What have you got? Any pics?
cheers
I’ll get some pictures tomorrow mate any idea what you want and I’ll look through the boxes
You may have some bits in better condition than mine etc.
Let me know when pics are up.
cheers
Ok there’s loads of small stuff I’ll get some pictures tomorrow
On 23/04/2020 at 12:33, dvderlm said:
Ignition leads :
M4 connectors.
Only just seen this message I’m new to the forum,Thanks for clearing that up much appreciated I’ll be getting round to the wiring in the next week or so just waiting on a gasket set to rebuild the engine 👍
cheers
Do you have a iPhone I can send pictures to mate I don’t have a clue how to use this forum
Iv put pictures on a ad for mk1 polo in the classifieds,cheers
I must be going blind lol. I can’t find it. Can you put the link up?
cheers
If you go on the bodywork and interior part of the classifieds the main picture is a back light mate I don’t know how to send the link
