Polo Classic (6kn)
Hello, I´m from Brazil.
I have a Polo classic (6KN) and buied a VAG-COM to access the ECU.
What parameters i can adjust with Vag-com in my car? The engine (1.8 liter M.P.F.I - Gasoline) and ECU (MAGNETTI MARELLI 1AVB) is similar with Golf MK3 inBrazil.
  • Views 764
  • caretakerplus
    caretakerplus
    Welcome to the Forum.   A lot depends on what you have actually purchased - If it is a cheap Chinese copy, maybe you won't be able to do much more than read fault codes and maybe clear (dele
A lot depends on what you have actually purchased - If it is a cheap Chinese copy, maybe you won't be able to do much more than read fault codes and maybe clear (delete) them.
All that I can suggest, is that you experiment with it and see exactly what it will do.
Regards.
Hello,
I Tested the VAG-COM in my car and got it read the parameters of sensors in real time and fault codes.  the lambda sensor was in trouble.
With the device i finnaly solved my problem.
I Can´t change parameters or reset adaptive parameters in my car, but I believe it is because the ECU is old.
My engine was rectified to primary measure three weeks ago, the car is very good now.
follow one picture of my car:P_20200411_101246.thumb.jpg.0a4fe856e875a8b3cde45015e29f5d2e.jpg.
Glad that you have the problem sorted out.
Regards
