Burnt Exhaust Valves
A 3 pot engine will have shorter time between strokes than a 4 cylinder so even less time for valve cooling. Just what cylinder head recon was done?
Too hot spark plugs (wrong heat range) that don't take sufficient heat away to the  water jacket in my experience caused visible plug nose contact damage and that would misfire. Too cold can be a swine to start the engine with.
  • Replies 28
  • Views 10.4k
  • Supermarket fuel will not be the problem.  Approximately half of all petrol sold in the UK comes out of pumps at supermarkets, so this problem would be far more common if that were the cause. It'
  • No way of knowing when the damage happened, or started to happen really. Just make sure it gets regular oil/filter changes from now on.  I personally do the missus's Fabia (12-valve 1.2) twice a year,
  • j.hilmar.christens
    j.hilmar.christens
    I had oil change last year... Not doing that many miles as you know... Filter too and sparks... Thanks for all your advise Pete!
Thought you might want update, turns out still had silent misfire, change of injector helped... Also Cat 🙀 might need changed, got the cat cleaner stuff from Halfords...the cam sensor that was changed, think it's wiring fault as goes on and off.... Car running a dream at idle now...
I had all cylinders reconed... Seen pics?
Edited by j.hilmar.christens
Glad it is running better at idle.
Partially blocked cat won't help power.
Any fault codes?
