6n1 Correct Transmission Fluid
I have a 1999 6n1 1.4  AEX Engine, 4 speed auto need to change the transmission fluid.
My searches have shown G052990A2 and  G052162A2 after much reading am unable to conclude which is really the correct fluid, can someone please confirm for me.
Thanks.
  • Replies 8
  • Views 929
Thanks.
Am trying to locate a cheaper substitute but my choices are very limited here in Jamaica will this Febi Bilstein # 29934 work for this model?
Thanks
There's a button over in the rightmost column of that page I linked, with aftermarket equivalents. Here's a screenshot of what comes up for G 052990A2:
I was looking at the Febi 27001 planning to buy it on Ebay or Amazon but when I search I only found 1 qt on Amazon and on Ebay when you go in the details the number on the bottles are  the 29934, so was wondering if it was a substitute.
Dunno; you'd have to ask Febi, somehow.
I am ging to use this Amsoil product it says it conforms to the following: vw spec g052990a2
AMSOIL Signature Series Multi-Vehicle Synthetic ATF is recommended for transmissions, hydraulics, power steering systems and other applications that require any of the following specifications: Allison C-4, TES-389; BMW 7045E, 8072B, LA 2634, LT 71141; Chrysler ATF+4*, MOPAR* ASRC, 68089195AA, 68049954AA; Ford MERCON*, MERCON* V, ESP-M2C166-H, FNR5, M2C924-A, XL-12; GM DEXRON* II, DEXRON* III, AutoTrak II; Honda/Acura ATF-Z1; Hyundai/Kia SP-II, SP-III, Red-1; IDEMITSU K17; JASO 1A; JWS 3309, 3314, 3317; MAN 339 Type V-1, 339 Type V-2, 339 Type Z-1, 339 Type Z-2, 339 Type Z-3, 339F; Mazda ATF-M III, ATF-MV, F-1; Mercedes Benz 236.1, 236.2, 236.3, 236.5, 236.6, 236.7, 236.9, 236.10, 236.11, 236.81, 236.91; Mitsubishi SP-II, SP-III, ATF-J2; Nissan Matic-D, Matic-J, Matic-K
Amsoil.pdf
402; SAAB 3309; Shell 3403, LA 2634; Subaru ATF, ATF-HP; Suzuki 3314, 3317; Texaco ETL-7045E, ETL-8072B, N402; Toyota Type T, T-II, T-III, T-IV; Voith 55.6335, 55.6336; Volvo 97340, 97341; VW/Audi G 052 162, G 052 990, G 055 025; ZF TE-ML 03D, 04D, 05L, 09, 11A, 11B, 14A, 14B, 14C, 16L, 16M, 17C, 20B, 20C, 21L.
