Mk2 Coupe S - G40 Engine Loom Conversion
test that thin starter wire with a meter when the key is on ...needs to see 12v
and /or put 12v to it and see if starter spins
  • Replies 51
  • Views 4.1k
  • steveo3002
    steveo3002
    yeah ok...so best get the interior wiring for the pump from any mk2f...not too bad to make up if you had to    and yeah the g40 engine should just go in on its own pretty much like it says i
  • steveo3002
    steveo3002
    you can just drag or past photos here   yeah that plug is confusing ...i think its just so you can pull the looms seperatly
  • Brown wires are ground/earths
Theres no power getting to the thin blue wire, I have PM'd you mate
